yoh-dah
Feb 22, 2006Guide
ReadyNAS Device Compatibility List
ReadyNAS Device Compatibility List can be found here. Edited March 27, 2009.
yahui168
May 24, 2007Aspirant
I said previously that the HP Deskjet 880c works and that you just have to install the driver from you computer. If you are using Vista there is no 880c, you have to select HP Deskjet 882c. This is the correct driver because if you attach the printer to your computer via USB, Vista will select 882c. You can select 880c in XP.
