yoh-dah
Feb 22, 2006Guide
ReadyNAS Device Compatibility List
ReadyNAS Device Compatibility List can be found here. Edited March 27, 2009.
bhoar
Oct 15, 2007Aspirant
steffi wrote: Can anybody tell me if WRT54G version 2 Linksys wireless routers are supported/compatible?
Any settings required?
I can't recommend directly connecting a readynas to a 100mbps router port. One reason is that the integrated switch in the router chipsets is often a very poor performer, often limited to 30-40mbps of throughput.
It can server as your internet gateway just fine, however, it's best to have the readynas's first hop be a dedicated switch (preferably a gigabit switch...or a gigabit router listed on the HCL with a real switch chipset).
-brendan
