yoh-dah
Feb 22, 2006Guide
ReadyNAS Device Compatibility List
ReadyNAS Device Compatibility List can be found here. Edited March 27, 2009.
chirpa
Apr 29, 2008Luminary
I would say it is accurate, the drives can show problems, so they are not currently on the list. As said many times, when WD makes an update that works, they will be re-added. Having them on the list right now will just get even more support calls saying 'im getting ata errors on my drives'. It wasn't a mistake, and you can still use your drives, just keep disk spin-down disabled until it is worked out.
ajwhitlock wrote: The HCL list needs to be accurate. Any mistakes that are made need to be covered by Netgear.
