yoh-dah
Feb 22, 2006Guide
ReadyNAS Device Compatibility List
ReadyNAS Device Compatibility List can be found here. Edited March 27, 2009.
confmed
Dec 30, 2008Aspirant
Han Solo wrote: Hi Rainbowman,
Support for the Seagate 1.5TB drives is in the latest release (4.1.4) that it looks like you downloaded already. The problem you are reporting looks like it could actually be a bad drive. What I would recommend is to use Seatools on the drive to verify if the drive is OK or not. If you are unfamiliar with Seatools please let me know and I will help you out.
Han Solo --
I'd like to run Seatools to check one of the drives installed on my ReadyNAS. It has been reporting warning messages pretty much since I got it (about 7 months ago) saying the following:
> Reallocated sector count has increased in the last day.
> Disk 3:
> Previous count: 15
> Current count: 16
> Growing SMART errors indicate a disk that may fail soon. If the errors continue to increase, you should be prepared to replace the disk.
Anyways, I have the impression that running Seatools is intended for internal drives or external drives which you connect to via USB. I however connect to the drives in my ReadyNAS via my local network. Will Seatools work given this setup?
Thanks in advance.
