yoh-dah
Feb 22, 2006Guide
ReadyNAS Device Compatibility List
ReadyNAS Device Compatibility List can be found here. Edited March 27, 2009.
manfredell
Sep 23, 2009Aspirant
Han Solo wrote:
manfredell wrote:
Han Solo wrote:
The WD20EADS are next on the list.
Great. Does this mean I can use this patch (already installed) and use the drives (waiting)?
Thx!
Unfortunately No. The patch only works on the WD2002FYPS 2TB RE4 GP drives. The command set used in the patch does not work on the WD20EADS. This is a limitation that WD has on the WD20EADS drives. We are working with WD to come up with a patch that will support both the WD20EADS and the WD2002FYPS drives.
OK. I have installed the patch. I presume that this won't be a problem when you release the patch for the WD20EADS? If yes, than how do I uninstall this one?
Thx again
