yoh-dah
Feb 22, 2006Guide
ReadyNAS Device Compatibility List
ReadyNAS Device Compatibility List can be found here. Edited March 27, 2009.
Han_Solo
Sep 23, 2009Tutor
manfredell wrote:
OK. I have installed the patch. I presume that this won't be a problem when you release the patch for the WD20EADS? If yes, than how do I uninstall this one?
Thx again
It will not be an issue. We will make sure to remove the old one and use the newer version.
