yoh-dah
Feb 22, 2006Guide
ReadyNAS Device Compatibility List
ReadyNAS Device Compatibility List can be found here. Edited March 27, 2009.
rejemy
Sep 25, 2009Aspirant
I concur with manfredell -- after installing this patch, you can no longer reboot the system from Frontview. When you select to reboot and hit apply it just immediately takes you back to the main status page. I've tried this using both Firefox and Safari with the same result. I haven't tested shutting it down with the power button on the front, but using 'reboot' after SSHing into the box works fine. I'm assuming the power button would also work to bring the box down safely.
