yoh-dah
Feb 22, 2006Guide
ReadyNAS Device Compatibility List
ReadyNAS Device Compatibility List can be found here. Edited March 27, 2009.
manfredell
Sep 25, 2009Aspirant
rejemy wrote: I concur with manfredell -- after installing this patch, you can no longer reboot the system from Frontview. When you select to reboot and hit apply it just immediately takes you back to the main status page. I've tried this using both Firefox and Safari with the same result. I haven't tested shutting it down with the power button on the front, but using 'reboot' after SSHing into the box works fine. I'm assuming the power button would also work to bring the box down safely.
Thanks for testing this and reporting. This was drivinf me nuts!!!
The issue is not only not being able to reboot but also to
-start filechecks and sorts
-factory restore
and possibly others
How can they release such a "PATCH"??????
