yoh-dah
Feb 22, 2006Guide
ReadyNAS Device Compatibility List
ReadyNAS Device Compatibility List can be found here. Edited March 27, 2009.
gosand
Nov 30, 2009Aspirant
Ok, venting done. Back to the issue at hand - the firmware update that will enable use of the wd20eads drives.
- Are we talking next week, or 6 months from now ? They've been out for just over 10 months now, so I'm hoping the "fix" is right around the corner ?
- Will the fix require drive firmware updates and/or manual idle settings, etc., (insert ridiculous DOS procedure here) ? If so, will this be detailed with the firmware update ?
Thanks.
Thanks.
