yoh-dah
Feb 22, 2006Guide
ReadyNAS Device Compatibility List
ReadyNAS Device Compatibility List can be found here. Edited March 27, 2009.
InterClaw
Dec 02, 2009Aspirant
mdgm wrote:
InterClaw wrote:
mdgm wrote: NetGear will not add disks to the HCL until they are satisfied that they are compatible.
As always, everyone can still make a mistake though. ;)
Yes, but we can't expect NetGear to add disks quickly to the HCL if we mistakenly pruchase them not realising that those disks are incompatible.
Actually, those disks WERE on the HCL and were later removed, because they didn't work properly at that time. I purchased them when they were "compatible".
Anyway, that's water under the bridge. The drives were later re-added to the HCL. What I meant to say is just that anyone can make a mistake - even the Jedis it seems. :wink:
