yoh-dah
Feb 22, 2006Guide
ReadyNAS Device Compatibility List
ReadyNAS Device Compatibility List can be found here. Edited March 27, 2009.
enkrypt3d
Jan 07, 2010Tutor
Just wanted to let u know my ReadyNAS NVX Pioneer is working great w/ 4 x 1TB WD a Netgear GS108T (it worked well w/ the GS108 but that switch didn't support LACP so I upgraded to the GS108T and am very happy)
Also w/ these drives w/ no problems:
RAID Disks:
Ch 1 : WDC WD10EADS-00P8B0 [931 GB] 927 GB allocated
Ch 2 : WDC WD10EADS-65M2B0 [931 GB] 927 GB allocated
Ch 3 : WDC WD10EADS-00L5B1 [931 GB] 927 GB allocated
Ch 4 : WDC WD10EADS-00L5B1 [931 GB] 927 GB allocated
One question, will this memory work in my NVX?
4GB stick:
http://www.newegg.com/Product/Product.a ... 6820148288
or 2GB stick:
http://www.newegg.com/Product/Product.a ... 6820148162
Also what is the maximum ram that can go in the NVX? This info wasn't on the FAQ or the HCL.. Thanks!
RAID Disks:
4GB stick:
or 2GB stick:
