yoh-dah
Feb 22, 2006Guide
ReadyNAS Device Compatibility List
ReadyNAS Device Compatibility List can be found here. Edited March 27, 2009.
GlobalMind
Feb 24, 2010Aspirant
johlar wrote: Hi.
I am using Western Digital WD10EADS-00L5B1 1TB disk in my ReadyNas Duo and it works fine.
I have had no problems with it, and the temperature is "normal".
Tought you should know so you can add this to the compatibility list;)
What code level on the Duo are you running?
