yoh-dah
Feb 22, 2006Guide
ReadyNAS Device Compatibility List
ReadyNAS Device Compatibility List can be found here. Edited March 27, 2009.
Persson
Jun 10, 2010Aspirant
Well thought that I would add to the now 2 year old inaccuracy of the HCL list.
the APC CS 500 is reported as incompatible with a NVX by a user mash .
Today tested my APC CS-500 after having received the P10C10 to USB cable part number 940-0127E FCI
NVX with RAIDiator 4.2.11
- The log did not detect the connection of the UPS via the cable (the only problem)
- the Green indication litt up
- hovering the mouse over the light gave status information " APC CS-500 , 100% , 51 min"
- health information showed the same information
- Janking the power cable, caused a log entry, a display alert and a email message to be sent with on "battery power"
- followed the battery level sink for 15 min on the NVX admin interface.
- reconnected, another log entry "on line power", alert on "web display" and an email sent that power is ok.
(The log entry "power ok" is indicated with a flashing yellow light which you might argue is wrong it ought to be a green steady....)
only thing not tested is that the NVX initialises a shutdown at low battery, will do that a bit later.
So....searching through the forum, one user says that a firmware update a couple of years ago sorted this Cs 500 problem....
i would agree with that....
