yoh-dah
Feb 22, 2006Guide
ReadyNAS Device Compatibility List
ReadyNAS Device Compatibility List can be found here. Edited March 27, 2009.
cuccureddu
Jun 15, 2010Aspirant
I also wanted to report that the APC Back-ups CS 500 is compatible.
In my case, I have a ReadyNAS Duo. I am running the latest version of RAIDiator (4.1.6)
At first I thought the device was not compatible, as it took a while to detect it (or at least, for it to show up in Frontview). However, after 15 minutes or so, the UPS indicator in Frontview turned green, and Frontview displays "APC Back-UPS 500, Battery charge: 100%, 43 minutes" in the status page. I also tried disconnecting the power and the RND correctly detects this sends me alerts for when the UPS is on battery and then again when it's back on mains power.
The current hardware compatibility list shows it's not compatible, so I suggest it's changed to reflect my experience and that of the post before me, given that it seems to work both with RND and with NVX.
Thanks,
Rob
Thanks,
Rob
