yoh-dah
Feb 22, 2006Guide
ReadyNAS Device Compatibility List
ReadyNAS Device Compatibility List can be found here. Edited March 27, 2009.
pjc1
Sep 12, 2010Aspirant
5 months later, I have basically the same question. I don't see any Constellation series listed at all in the community compatibility list. The Constellations are approved for all the Intel-based products, but not the old Sparc-based ones.
schalliol wrote: I was thinking about buying some 2TB Seagate Constellation ST32000644NS drives. ... I see that they are listed as compatible on the ReadyNAS NVX and Pro models, but they are not listed for the NV+. Does anyone know why they might not work in the NV+ or whether they just have not been tested and should likely work? ...
Jedi, please test the Constellation drives with the NV+! If they're known not to work, please let us know!
I understand it's not as much of a priority to test new drives on old hardware, but the ES.2 drives are becoming hard to find. Frankly, even for a 1TB, it's easier to find a Constellation than an ES.2.
