yoh-dah
Feb 22, 2006Guide
ReadyNAS Device Compatibility List
ReadyNAS Device Compatibility List can be found here. Edited March 27, 2009.
mdgm-ntgr
Oct 29, 2010NETGEAR Employee Retired
hakwin wrote:
Stupid question: Are all the hard disks in the Duo list compatible?
Yes all the drives in that list are compatible with the Duo.
hakwin wrote:
Does it not matter which one I pick?
I would avoid the WD Green disks for now, particularly the WD 2TB one.
hakwin wrote:
I see that there are 2TB options there, but I thought 1TB was the maximum size for each disk?
1TB used to be the maximum when 1TB disks were the max capacity disk available. Since 2TB disks came out, firmware updates have made it possible to use 2TB disks.
