yoh-dah
Feb 22, 2006Guide
ReadyNAS Device Compatibility List
ReadyNAS Device Compatibility List can be found here. Edited March 27, 2009.
sphardy1
Jun 10, 2011Apprentice
Regulus wrote: Thanks for the information ... but being a new user with a number of decades of ICT experience on the counter, I can't help feeling a bit weird having to go through all these "compatibility" search issues instead of just not having to worry about this because the ReadyNas could be built following general & international connectivity standards ... :roll:
The only compatibility list that is important is for HDDs you install in your NAS - and given you are trusting your data to a product that is designed to protect that data, it doesn't seem unreasonable that a NAS manufacturer would want to have some semblance of control over the required 3rd party products that can have a significant impact on the reliability of their own product
The other HCLs are guides and far from complete or exhaustive as explained - ideally any router or switch conforming to appropriate standards should work as you refer, but as I'm sure you've found in your decades of ICT experience, that is far from always the case - and not just with NAS devices
