yoh-dah
Feb 22, 2006Guide
ReadyNAS Device Compatibility List
ReadyNAS Device Compatibility List can be found here. Edited March 27, 2009.
mdgm-ntgr
Jun 13, 2011NETGEAR Employee Retired
Pence1 wrote: http://www.readynas.com/?page_id=84
Netgear is losing thousands of dollars because of the very outdated Compatibility list like the one above,
Please update them or just dont make it available if inadequate or incomplete. :x
That's a guide as to what you should purchase if you don't already have a router/switch. It should give you some indication of what is and isn't likely to work. It's impossible to test all the switches and routers out there. If your router/switch works fine then great.
The important things to do are to stick to the compatibility list for drives to put in your NAS; and to not upgrade the RAM in your NAS.
