yoh-dah
Feb 22, 2006Guide
ReadyNAS Device Compatibility List
ReadyNAS Device Compatibility List can be found here. Edited March 27, 2009.
ReadyNASUser
Mar 09, 2012Aspirant
StephenB wrote: 2 TB is the limit for V1 (sparc-based products).
AndrewL1963 wrote: Have anyone had any luck with 3TB drives in the NV+ V1? Already using 4 x 1.5TB but space now at a premium. Over the last 6 years have gone from 750 to 1TB to 1.5TB so would like to save some time and money and jump straight to the 3TB.
1. Does that limit also apply to external USB drives? i.e. if I have 4 x 1TB installed in NV+, giving approx 2.8Gb usable, and I need to backup to a USB drive I need a 3Gb disk... with it work on an NV+?
2. For drives in a NV+ X-RAID array is 2Gb a hardware limit or a software limit? (i.e. any likelihood the limit can or will be removed)
OK I have my answer to 1. its no unfortunately... so if you put in 4x 1TB or 1.5TB drives you can't back them up to a single USB drive - disappointing - http://www.readynas.com/forum/viewtopic.php?f=109&t=46175#p299584
Whats the answer to #2?
