yoh-dah
Feb 22, 2006Guide
ReadyNAS Device Compatibility List
ReadyNAS Device Compatibility List can be found here. Edited March 27, 2009.
Apr 27, 2012Guru - Experienced User
I feel your pain. Though issues with drives on the HCL are fortunately rare.
MD0MDI wrote: The problem is which one??? I have already tried one from the list which i have then been told is not compatible, and i have now lost out on £28 return postage to send the drives back, so which ones that are on the list will work, or is this list just going to be full of drives that are not compatible???
No one seems to give me a correct answer, and even telephoning Netgear here is the UK has proved to be useless, I am really seeing the level of customer support that Netgear offer!, i.e. NONE!
Mgdm has suggested Hitachi more than once, perhaps you can pick one in your price range, and go with it.
