yoh-dah
Feb 22, 2006Guide
ReadyNAS Device Compatibility List
ReadyNAS Device Compatibility List can be found here. Edited March 27, 2009.
mdgm-ntgr
May 22, 2012NETGEAR Employee Retired
rvarttinen wrote:
Further, it has a RS232 port, but the manufacturer provides a RS232 to USB converter cable. Will that work with the NAS?
No. See http://www.readynas.com/kb/faq/hardware/can_i_use_a_serial-to-usb_converter_from_a_serial_port-only_ups_to_the_readynas
rvarttinen wrote:
What does the NAS actually require connectionwise?
UPS with USB port or APC unit with SNMP card.
rvarttinen wrote:
Are there other solutions; connecting the UPS to a PC that has the capability to signal power down over the LAN?
Not sure if this is possible, but don't think I'd recommend that. There are plenty of compatible UPS units. What is a DIN-rail mount btw?
