yoh-dah
Feb 22, 2006Guide
ReadyNAS Device Compatibility List
ReadyNAS Device Compatibility List can be found here. Edited March 27, 2009.
rvarttinen
May 22, 2012Aspirant
No not really, it is different; the devics are quite small (physical size) and does not have the depth as a 19" unit. On a DIN-rail you count units, and one of these devices takes up a number of units, whereas a fuse (auto) takes up one unit (small, narrow).
Check out this image, it give a fairly good view of how DIN-mounted devices looks like, with four devices each taking a unit each:
http://www.google.se/imgres?hl=sv&sa=X&biw=1710&bih=974&tbm=isch&prmd=imvns&tbnid=jGfdZMJmVPbGkM:&imgrefurl=http://www.omega.com/ppt/pptsc_lg.asp%3Fref%3Ddrg-sc&docid=9wp2HgIDB8KF1M&imgurl=http://www.omega.com/DAS/images/DRG-SC_l.jpg&w=450&h=381&ei=44O7T9j2BYzP4QT08vTwCQ&zoom=1&iact=hc&vpx=183&vpy=622&dur=15&hovh=207&hovw=244&tx=85&ty=110&sig=104185509124892429713&page=1&tbnh=143&tbnw=169&start=0&ndsp=40&ved=1t:429,r:24,s:0,i:123
