yoh-dah
Feb 22, 2006Guide
ReadyNAS Device Compatibility List
ReadyNAS Device Compatibility List can be found here. Edited March 27, 2009.
nvplus
Aug 03, 2012Aspirant
I also have been caught by same problem. We have a ReadyNAS NV+ and my supplier does not have any other replacement disc for it than a ST1000NM0011 which does not appear on the Netgear HCL. Does anyone know if it is compatible with the NV+ and if it possible to mix this disc with the current ST31000340AS (I think) discs?
The supplier also said that it would be compatible while reffering to "Netgears QVL, 5010462056". Anyone knowing what it reffers to?
/nvplus
/nvplus
