yoh-dah
Feb 22, 2006Guide
ReadyNAS Device Compatibility List
ReadyNAS Device Compatibility List can be found here. Edited March 27, 2009.
Apr 02, 2013Guru - Experienced User
Generally I think that the red drives are better for NAS/RAID use than the green drives.
There is no problem mixing drives models Also, you can mix sata 6gb with sata 3gb, as sata itself is backwards compatible. Also, mechanical hard drives are all much slower than even 3 gb SATA (they peak at ~150 MB/s or ~1.2 gbs).
