yoh-dah
Feb 22, 2006Guide
ReadyNAS Device Compatibility List
ReadyNAS Device Compatibility List can be found here. Edited March 27, 2009.
Dec 30, 2013Guru - Experienced User
You can't add a 2 TB drive since you started with 4 TB drives.
Are you sure the error was because the drives weren't on the HCL? What size was the barracuda? Did you actually add it, or did you do a factory reset with the seagate in place?
