yoh-dah
Feb 22, 2006Guide
ReadyNAS Device Compatibility List
ReadyNAS Device Compatibility List can be found here. Edited March 27, 2009.
mdgm-ntgr
Jul 27, 2014NETGEAR Employee Retired
It's not just a simple matter of adding a few items to a list.
Disks have to be tested in a range of models and if they fail to meet the required standard, then the reason for the failure has to be diagnosed and if it is a software issue be addressed in a firmware update and then the tests have to be run all over again.
So we can't provide an estimate as to when disks might be added to the compatibility list.
What models are you interested in using 5TB and 6TB disks with?
