yoh-dah
Feb 22, 2006Guide
ReadyNAS Device Compatibility List
ReadyNAS Device Compatibility List can be found here. Edited March 27, 2009.
Aug 14, 2014Guru - Experienced User
It's not on the official list (though you aren't under warranty support anyway if you purchased when you joined the forum).
gidu wrote: My NETGEAR RND2000 V1 is full and i need to change my hard drives, (two SAMSUNG 1TB), so, is these HDD are compatible with my RND200 V1 : Western Digital Green Desktop WD20EZRX - 3.5'' SATA III IntelliPower cache 64 Mo 2 To ?
I'd get the WD20EFRX instead. I use one in my duo, and have had no problems. It's intended for NAS, and has a 3 year warranty (the EZRX only has a 1 year).
