yoh-dah
Feb 22, 2006Guide
ReadyNAS Device Compatibility List
ReadyNAS Device Compatibility List can be found here. Edited March 27, 2009.
crond
Sep 28, 2014Aspirant
Hi Tijgert,
Do you still plan to post your reply on this topic ?
From your signature I see you already using 6th WD RED on ultra 6 NAS, correct ? I'm asking because I'm considering to buy 4x for ultra4 NAS
tijgert wrote: Thanks for the reply, appreciate it.
I was asking the same question in two topics because both topics were relevant to my question and vice versa.
To be future similar question asking users of service I will gladly point them to that other topic -> http://www.readynas.com/forum/viewtopic.php?f=24&t=70222&p=432196#p432196
I no longer have tech support so I'll have to chance it. I just wanted a reason not to try it and so far there are none.
Also, another topic mentioned that any size drive should work on any x86 box as GPT drives are not size limited. They are on ARM boxes though.
So drives are on order (plus I can return the unused ones anyway).
I will post my results in THIS topic as compatability of these drives are directly applicable to this topic.
