yoh-dah
Feb 22, 2006Guide
ReadyNAS Device Compatibility List
ReadyNAS Device Compatibility List can be found here. Edited March 27, 2009.
mdgm-ntgr
Nov 30, 2014NETGEAR Employee Retired
You can use 5TB disks on either OS4 or OS6.
But on OS4 you would have to do a factory default with all the 5TB drives in place. If you need a higher volume capacity again with OS4 you would need to do another factory default with the higher capacity disks in place.
We have a long thread on this here: http://www.readynas.com/forum/viewtopic.php?f=160&t=70133
