yoh-dah
Feb 22, 2006Guide
ReadyNAS Device Compatibility List
ReadyNAS Device Compatibility List can be found here. Edited March 27, 2009.
oldtimer67
Dec 01, 2014Aspirant
mdgm wrote:
oldtimer67 wrote: I have a readynas nv+ .... I would like to know if I can use the 2TB Western Digital WD2003FZEX which replaced the WD2002FAEX that is on the hardware compatibility list. Thanks so much.
Can you email me your logs (see link in my sig)?
I'm not having any trouble with my readnas nv+. Just wanted to know if the WD2003FZEX would work instead of the WD2002FAEX so I could expand it. The latter is discontinued. If the logs would help determine that I would be happy to send. Just want to be sure you need them to answer this. It looks like I should just make a copy of what's on there now and try it and see what happens. I just thought perhaps someone might already know. Thanks...
