yoh-dah
Feb 22, 2006Guide
ReadyNAS Device Compatibility List
ReadyNAS Device Compatibility List can be found here. Edited March 27, 2009.
Dec 01, 2014Guru - Experienced User
There is a thread here, perhaps not conclusive: viewtopic.php?f=24&t=77722
Based on this, I'd say that the drive works, but you might want to compare the power specs and the acoustic noise specs with the WD2002FAEX. WD20EFRX is another option (also not on the HCL, but which certainly works with the NV+). It is quieter and cooler than the FZEX drives (and of course slower, though the NV+ performance is limited mostly by the sparc CPU).
