yoh-dah
Feb 22, 2006Guide
ReadyNAS Device Compatibility List
ReadyNAS Device Compatibility List can be found here. Edited March 27, 2009.
Jan 12, 2015Guru - Experienced User
for 2x6TB it is official support. Netgear can/will deny you support if you use disks that aren't on the HCL.
albertoita wrote: I have a ReadyNAS 104 with firmware 6.2.2. On the hardware compatibility list I don't find any hdd with more than 4 GB capacity.
What this means? That if I install 2 hdd of 6 TB they are not recognized? Or it's just a question of official support?
4x6TB XRAID will actually fail, because there is a maximum volume size of 16 TiB on the RN100 series, and 4x6TB would have an 18 TB volume size.
