yoh-dah
Feb 22, 2006Guide
ReadyNAS Device Compatibility List
ReadyNAS Device Compatibility List can be found here. Edited March 27, 2009.
Jan 13, 2015Guru - Experienced User
Technically that should work, but AFAIK no one has posted any anything with 8 TB drives. The new seagate coming out is designed for archival (e.g., cold storage), so its performance in a NAS is unknown.
albertoita wrote: [so, if I create multiple volume manually (disabling X-RAID), I could install 4x6 TB HDD? And also 4x8 TB HDD?
Generally most people would want go to jbod in these cases - 2 RAID-1 volumes with 4z6TB drives would give you 12 TB of storage. You can get the same amount with 4x4TB xraid.
btw 4x5TB ought to work with xraid, the volume size would be 15 TB.
You lose automatic expansion (and RAID protection/bit-rot recovery if you choose jbod).
albertoita wrote: And which services/expansions I loose if I disable X-RAID?
