yoh-dah
Feb 22, 2006Guide
ReadyNAS Device Compatibility List
- yoh-dahGuide
tg3 wrote: I can confirm my GigE switch works fine with the ReadyNAS NV.
Netgear ProSafe GS116 (GigE, Jumbo Frames, 16 port, non-managed).
Have not tested the jumbo frame feature.
Much to my delight, GigE works fine on a home Cat 5 network installed nearly 10 years ago.
tg3, have you verified performance with IOMeter? It'll be good to get jumbo frame numbers before we put it on the list. Thanks! - Derek_K_AspirantI have successfully shared the printer in my Samsung SCX-4521F all-in-one under XP. Printing works fine and is pretty fast.
Is it even possible to share a scanner over the network? I wouldn't think so. - tg3AspirantI can confirm my GigE switch works fine with the ReadyNAS NV.
Much to my delight, GigE works fine on a home Cat 5 network installed nearly 10 years ago. - yoh-dahGuide
woodstock wrote: Not yet. The UPS is plugged into an outlet that is blocked by a heavy bookcase -- so it may be awhile before I can unplug it. I don't really want to start flipping breakers. :)
Here's something odd I just noticed about the UPS. On the Health page, it claims the battery charge is 120%/45min. 120%?
OK, I'll hold off on putting the UPS in our list. I haven't seen these UPS's before. Do you know if they're rebranded? - yoh-dahGuide
dedalo wrote: I have linked my two USB printers on ReadyNAS 600 and they are working.
Infrant ReadyNAS 600
RAIDiatorâ„¢ v3.00c1-p2 [1.00a131]
HP Deskjet 6540
HP officejet 5510
Thanks! - dedaloAspirantI have linked my two USB printers on ReadyNAS 600 and they are working.
HP Deskjet 6540
HP officejet 5510 - woodstockAspirantNot yet. The UPS is plugged into an outlet that is blocked by a heavy bookcase -- so it may be awhile before I can unplug it. I don't really want to start flipping breakers. :)
Here's something odd I just noticed about the UPS. On the Health page, it claims the battery charge is 120%/45min. 120%? - yoh-dahGuide
woodstock wrote: The following all work with my NV (v3.00c1-p2):
USB HARD DISKS / ENCLOSURES
Wolverine 2040 (enclosure contains 40GB Toshiba MK4025FAS laptop drive)
USB FLASH
SanDisk Cruzer mini 1GB
SanDisk Cruzer micro 512MB
VisionTek flash drive 512MB
USB PRINTERS
HP OfficeJet 7210 All-in-One
USB UPS
Dynex DX-800U (800AVR)
USB CAMERAS (new section?)
FujiFilm FinePix F10 (it appears as: USB_FLASH_# FUJIFILM USB-DRIVEUNIT)
Thanks!
For the UPS, did you run-down the battery and check for graceful shutdown? - woodstockAspirantThe following all work with my NV (v3.00c1-p2):
USB FLASH
USB PRINTERS
USB UPS
FujiFilm FinePix F10 (it appears as: USB_FLASH_# FUJIFILM USB-DRIVEUNIT) - yoh-dahGuide
kat_ams wrote: To add to the compatiblity list...
Konica Minolta Magicolor 2400W colour laser printer works great on the Ready NAS.
Thanks!
