yoh-dah
Feb 22, 2006Guide
ReadyNAS Device Compatibility List
- yoh-dahGuide
MaximG wrote: Hello everybody!
I'm happy to inform you that UPS APC 700VA Italian Version (BE700-IT) works correctly with ReadyNAS Duo (other UPS european version are similar).
I think UPS compatibility list should be updated. :D
It's been added. Thanks! - nvladikAspirantLinksys WRT54GS (Revision 5) works.
- yoh-dahGuide
nvladik wrote: Linksys WRT54GS (Revision 5) works.
Thanks. - _mjAspirant
D-Link DGS-2208 (Problems with switch over 10/100, further investigation required)
I've noticed this as well -- had to temporarily connect the NV+ and an old box with files I wanted to move to a 10/100 switch (Linksys BEFSR41 router) and everything was all good. The box can finally be retired so I reconnected the NV+ to my D-Link DGS-2208 switch with the rest of my GbE boxes. I'm still using the 10/100 router together with the D-Link switch with no problems whatsoever, although I haven't tried to access my NV+ from the internet... I'd be willing to assist with any investigation if it would be helpful for others.
I would also like to say that I'm very impressed overall with the NV+ it's a quality product. Props to the Jedi. :) - jayseaeAspirantWill the ReadyNAS NV+ be supporting the Seagate 1.5TB drives just announced? If so, any idea when, or if an update will be required? Thanks!
- Han_SoloTutor
jayseae wrote: Will the ReadyNAS NV+ be supporting the Seagate 1.5TB drives just announced? If so, any idea when, or if an update will be required? Thanks!
When they are available we will for sure do a drive qualification on them. As it stands right now with the current firmware on the NV+ will not have a problem with the size of this new drive. - jayseaeAspirant
Han Solo wrote: When they are available we will for sure do a drive qualification on them. As it stands right now with the current firmware on the NV+ the size of the drive will not be an issue.
Great - thanks for the quick response! - ixpahAspirantHello, I would like to report that the CyberPower 685AVR UPS works (for the most part) with a Netgear ReadyNAS Duo running RAIDiator 4.01c1-p2. The NAS detects the UPS as a CPS UPS BF700, and the NAS recognizes when the UPS switches to battery and proceeds to shutdown cleanly when the battery level becomes critical (the only thing that matters IMHO). The only bug I have noticed is that the battery level reads 12% when full. I believe this is actually 120%. When using battery power, the battery level drops to about 10% and then is suddenly at 95% or so, leading me to believe the UI is truncating the "120" to "12". The time remaining appears to be accurate despite the battery level bug.
- fatboymaximusAspirantI'm happy to announce that the Cyber Power Systems OR500LCDRM1U UPS works with my 1100. It's a nice UPS that's inexpensive and rack mount. It looks pretty good next to my 1100. It's given me no trouble for about two months (and one power failure).
I suspect that the other models in the family will also be supported because they're all using the USB HID UPS standard. Their model numbers look like:
ORXXXXLCDRM1U
Here's a link to the manufacturer's sight:
http://www.cyberpowersystems.com/produc ... t-lcd.html
Cheers
./m - ZappesAspirantOne for the printer section: Brother HL-1050 laser printer works like a charm.
