alexr114
Dec 26, 2011Aspirant
ReadyNAS Dilemma
Hi, I have been for some time now looking at getting a NAS drive and as I have scrapped some money together I am now looking into it more certainly. The reason for getting one is I stream alot of v...
Dec 26, 2011Guru - Experienced User
You can set up the Duo to use both drives for storage.
alexr114 wrote: ...the main question I was looking to ask which I can't seem to find anywhere is on lots of the reviews they say you can use one of the hard drives as a backup and the second hard drive gets mirrored. Is there a way that both drives can be used for storage and streaming or is it an automatic feature that you can only use one?
Note that there two models of RND2xxxx out there, and they are very different. So be careful to look at the part number info to know what you are buying.
The RND2000-200 is a brand new ARM-based product. It is much faster than the older Duo, but at present does not have as many features, and few community add-ons.
The RND2000-100 is a much slower product based on the SPARC processor. It supports more protocols and has a lot of add-ons.
