Red-Wagon
Feb 15, 2020Aspirant
ReadyNAS disables the ethernet ports when connected to Cisco switches
I have a new ReadyNAS 526x, fw 6.9.2 right out of the box. This is the second box with the exact same behaviour - first was RMA'ed. When I patch the NAS into our LAN Cisco SF200-24 switch it will no...
- Feb 15, 2020
Red-Wagon wrote:
When I patch the NAS into our LAN Cisco SF200-24 switch it will not connect
Part of the puzzle here is that the RN526x's 10GBase-T LAN ports won't connect to anything slower than gigabit ethernet - and the SF200 is a 10/100 switch. https://kb.netgear.com/30952/What-Ethernet-speeds-are-compatible-with-my-RN526x-or-RN626x
So I suggest checking the other devices that won't connect, and see which ones support gigabit. You can of course put a gigabit switch between the SF200 and the NAS. Or upgrade to an RN628x, which has two gigabit ports in addition to the two 10GBase-T ports.
schumaku
Feb 15, 2020Guru - Experienced User
StephenB wrote:
Red-Wagon wrote:When I patch the NAS into our LAN Cisco SF200-24 switch it will not connect
Indeed, most 10 GbE interfaces (and switches) don't support anything below Gigabit Ethernet.
Red-Wagon wrote:So again Joy connecting to :
Linksys EA9500 WiFi eithernet
D-Link workgroup switch
No Joy connecting to:
Cisco/Linksys workgroup switch
Dell laptop direct connect
D-Link WiFi ethernet
Cisco SF200 Switch <--LAN cable plant
Except of the EA9500 and the SF200, these marketing names don't allow to assist - impossible to guess what devices these are. One would need exact model designations. Older hardware and lower cost/power notebooks often came with Fast Ethernet only - an outdated standard when you consider using a NAS with it - you seriously don't win the storage race. Most users experience that Gigabit on the complete data path from the computer to the NAS somewhere between almost sufficient to non-sufficient.
The minimum you could so is - permitting the ports are not already in use - would be using one or two* of the the SF200 combo Gigabit ports (combo means you can either use the SFP slot typically for a fiber interface, or the RJ45 Gigabit interface) to connect the NAS. For using both ports, configuring a trunk/bond/LAG on the switch and on the NAS would be required.
