Rajesh13
Nov 05, 2025Follower
ReadyNas Disk test and its log report
ReadyNas 42400 disk test started but there is no progress or completion report; No detailed disk log available.
1 Reply
You will see the results on the logs page when the test completes.
You can also download the log zip file, and look at the disk health there. volume.log includes a section at the bottom that shows the maintenance tasks, and there will be an entry there showing the test start time (and the end time/results when it completes).
Also, disk_info.log and smart_history.log will give useful SMART stats info. dmesg.log and systemd-journal.log (among others) will show you errors.
If you are comfortable with ssh, you can also use smartctl.
