AndyNZ
Apr 29, 2013Aspirant
ReadyNAS Diskless and Disk Replacement (XPRESSHW)
If I purchase a diskless ReadyNAS with XPRESSHW using supported disks of my choice from the HCL (e.g WD30EFRX) - in the event of a drive failure will Netgear replace the disk like-for-like under the e...
mdgm-ntgr
Apr 29, 2013NETGEAR Employee Retired
Only disks included in a semi or fully populated unit would be covered. Disks you purchase separately would not be covered by NetGear.
The semi and fully populated units come with disks pre-installed which are chosen by NetGear. They would use disks from the compatibility list.
