AndyNZ
Apr 29, 2013Aspirant
ReadyNAS Diskless and Disk Replacement (XPRESSHW)
If I purchase a diskless ReadyNAS with XPRESSHW using supported disks of my choice from the HCL (e.g WD30EFRX) - in the event of a drive failure will Netgear replace the disk like-for-like under the e...
AndyNZ
Thanks for the prompt reply - is there an official support statement anywhere?
In a semi-populated unit, where additional disks have been purchased - i'd assume these also would not be supported?
Only drives on the HCL would be used.
