AndyNZ
Apr 29, 2013Aspirant
ReadyNAS Diskless and Disk Replacement (XPRESSHW)
If I purchase a diskless ReadyNAS with XPRESSHW using supported disks of my choice from the HCL (e.g WD30EFRX) - in the event of a drive failure will Netgear replace the disk like-for-like under the e...
mdgm-ntgr
Apr 29, 2013NETGEAR Employee Retired
It's been mentioned several times on the forum before. Unfortunately there is no way to tell which model disk is included in a semi or fully populated ReadyNAS until you purchase it. You can hardly expect NetGear to provide warranty coverage to replace defective disks not purchased from them.
