sylvainp
Nov 11, 2019Aspirant
ReadyNAS DLNA - OS6
Hi all, I recently bought a Auralic Altair G1 (streamer/DAC/preamp) and I have some issue with playing DSD files with the Auralic.
The Auralic can play DSD files. I have a Share folder for music with FLAC and DSD (.dsf) and I use SMB and DLNA.
When I use the share folder from the ReadyNAS in the Auralic Lightning DS apps I can see all the FLAC and also the folders for the DSD but I don't see the DSD files. On the Auralic forum they say I only need SMB v1 but when I activate SMB only for my share it doesn't show anything in the Lightning DS app. So I guess I really need the DLNA for the share folder.
Could it be possible that DLNA is not compatible or not broadcasting the DSD files ?
If I use the Auralic Lightning DS Server then I see the DSD files but at the moment I don't find the Lightning DS Server stable and my Auralic Altair G1 crash and freeze a couple of time during the weekend.
Anyone know a good music server compatible with Auralic ? Not much apps is available for netgear products as a plug in.
Minimserver seems to be popular (free) but no plugin or apps for Netgear
BubbleUPNP (but no plugin or apps for Netgear)
Asset (not free)
My Readynas is getting old and not supportesd anymore but I upgrade the CPU and RAM and it's rock solid. Maybe it's time to change for more popular brand....
Thanks
The DLNA protocol itself can handle it, but I'm pretty sure the two servers available in the NAS don't.
- Plex can transcode DSF, but I don't think there's any passthrough mode for it.
- The built-in DLNA (MiniDLNA) doesn't handle it. MiniDLNA has apparently morphed into ReadyMedia, and there is a plug-in that could be installed that is supposed to handle DSD. But I don't believe anyone has looked into getting that to work with the NAS.
Do you see the files when you examine the folder from a PC?
I think you will find that the SMB support requires a Lightning Server. Do you have that running?
The app store is definitely limited. But many things can be installed manually with ssh if you know how. If you have a legacy NAS, then one limitation is the the linux version in the older NAS is also quite old.
FWIW, insisting on running apps natively on a NAS not only limits your options, but also can lock you in later on when you want to add applications or replace the NAS. This could happen with any NAS vendor. One option you might consider is setting up a separate application server that has the media on the NAS mounted. That server could be a PC or linux server (depending on the application requirements, a Raspberry Pi might do). I'm not saying this approach is for everyone, but if you want the most flexibility it is something you might consider.
- sylvainpAspirant
Yes, when I go with the PC I can see the .dsf files and I can also play them on the PC using Foorbar with DSD plugin.
The auralic see the DSD folders but not the .dsf files contains in the folders.
it's strange on the PC I see the files and not with the Auralic. Maybe it has something to do with the DLNA version in the OS 6.
Yes - as I said earlier, the built in DLNA (minidlna) doesn't support that format.
I think you need to install a lightning server on the PC that is set up to access the NAS media shares, and use that instead of the NAS DLNA. Then the app would see it (when the PC is on). https://support.auralic.com/hc/en-us/categories/200358867-AURALiC-Lightning-Server
