tigerten
Apr 05, 2023Luminary
ReadyNAS does not boot internal M.2 SATA drive
I was hoping i could boot from the internal M.2 drive. If doe snot. It recognizes it, but not in the GUI.
tigerten
Apr 07, 2023Luminary
Re: the M.2 drive, after booting into the ESXi installation USB drive, the M.2 drive is not in there as a possible target for installation. So the ESXi does not detect the M.2. Does this mean you can not chain load the M.2 at all?
I understand bootable and accessible is not the same thing. BIOS controls whether a drive is bootable. Even if it is not bootable, it should still be accessible. You can still install on the drive, it just won't boot from it.
This is exactly the case with my Lenovo P300. I could install ESXi to the NVME drive, but I could not boot from it.
tigerten
Apr 19, 2023Luminary
Additional info:
ReadyNAS does not boot from the eSATA drive, it boots from the rear USB drives as well.
