Croftcroyne's avatar
Croftcroyne
ReadyNAS Duo - Can't boot, fan running fast
RND2110-100UKS with 2x 1Tb drives, now 5 yrs old. Today switched on a couple of hours ago, fan running fast, power blue light flashing, and unable to access from Windows 10 (using RAIDAR 6.5.0 which has been working v well). Prolonger attempt to switch off at the power button fails. I'm reluctant to pull the plug. Any thoughts would be gratefully received!
  • Eventually pulled the plug, now running and accessible via RAIDAR. Do I need to be concerned? No email received from the device.No error message in logs on admin page and all seems healthy. ??
    • StephenB's avatar
      It's an old NAS, and of course it isn't supposed to run that way.
      Do you have a backup plan in place for the files?
      Also, I suggest downloading the full log zip file, and looking in there for errors.  The summary in the web ui leaves out a lot of stuff.
      • Croftcroyne's avatar
        Croftcroyne
        Hi Stephen, Thankyou. The logs failed to download, and then I couldnt access the admin, switched off and on but failed to connect with RAIDAR sometimes RAIDAR sees it and tells me the disks are fine, but I am unable to browse or log in. Is there anyway, if I remove a disk and plus into windows that the OS would read it?
ProSupport for Business
