ripface
Aug 31, 2011Aspirant
ReadyNAS Duo - Disk issue
Hi All, I recently purchased two new 2TB disks to upgrade my ReadyNAS Duo. I picked the WD20EARS Caviar Green from the compatibility list. I removed my old 500GB drives one at a time and replaced...
mdgm-ntgr
Aug 31, 2011NETGEAR Employee Retired
You might wish to backup your data and then factory reset with the new drives in place. Particularly if your 500GB disks are not 4k sector aligned.
Take a look at Why you might want to factory reset a Sparc ReadyNAS
