MGARacing
Jul 30, 2022Aspirant
ReadyNAS Duo - Final Firmware update ? -> ERR_SSL_VERSION_OR_CIPHER_MISMATCH
Hey NetGear. It's not cool you have end of life-ed these devices so they are no longer accessible. These are archive devices which we entrusted Netgear with large amounts of our data. They were b...
- Sep 02, 2022
MGARacing wrote:
However Windows File Explorer still won't connect to my shares and therefore I can't easily access my files as I once could. What have I missed please ?
First check that the SMB 1/CIFS client is enabled on the PC. Do this by going into "turn windows features on or off".
If that's not enough, then try this test:
Open CMD from the Windows search bar, and then enter:
net use * /delete /y net use t: \\NAS-IP-ADDRESS\SHARENAME /user:admin NAS-ADMIN-PASSWORDsubstituting real values for the stuff in caps. Be careful on the typing - particularly on spaces and the two different slashes used in these commands.
If this works, it will map the share to drive letter T. Let us know what happens (and what error you get if it fails).
Sep 02, 2022Guru - Experienced User
MGARacing
Sep 02, 2022Aspirant
Absolute Star Richard.
Many thanks indeed.
IT Project Managers are no match for IT Engineers Guru's.
