hyopained
Nov 20, 2023Aspirant
ReadyNas Duo - unable to to access via Router
Hi all, I'm in desperate straits. We have many volumes of media (photos, videos) on our ReadyNas Duo that need to be accessed. We stopped using the device a few years back and the local SSD drive...
Sandshark
Nov 20, 2023Sensei
What does RAIDar show? If the NAS doesn't show up with drives installed, try without them (but label them so they go back in the same slots).
Yes, you have a V1. A "real" V2 says so on the front, not just a sticker. Netgear really messed up using the V2 moniker when they'd already done so. But the V2 also never shipped with drives, so a 2110 has to be a V1.
Once you know the NAS is on the network, you will still have some issues:
If you previously assigned a static IP address from within the NAS GUI and have since re-configured, you are going to have to deal with that. There are a couple ways to do that, but let us know if you need it.
Your NAS only supports SMB, which are depreciated in Windows, and TLS1.0, which is disabled in modern browsers, respectively. You can turn SMB1 on in Windows, and there are work-around for TLS1.0 that are discussed in multiple posts in the forum.
