hamslice
Jul 11, 2020Aspirant
ReadyNAS Duo 2110 V1 not seen by Yamaha R-N602 Amplifier
With the help of this board, I managed to get my elderly ReadyNAS recognised by both my Virgin Hub 3.0 over ethernet and my windows laptop over that wifi. The Yamaha R-N602 Amp sees my laptop over ...
- Jul 11, 2020
You are runing an ancient version of the OS, and a Beta one at that. Before you do anything else, you need to get it updated.
The only protocols your amp suports are it's propritary MusicCast and DLNA. Since MusicCast is for portable devices, you need to use DLNA with the NAS. You could use DLNA installed on the NAS, or you could use a PC with DLNA with the NAS just as a storage device for that PC.
Sandshark
Jul 11, 2020Sensei
hamslice
Thanks!
Will try the update again :)
should 4.1.16 work to update the beta?
