poisonrain
Dec 04, 2011Aspirant
ReadyNas Duo 2nd disk problem
Hi, I've had a ReadyNAS Duo for a couple of years and it's generally been ok, but has a weird 'feature' which is now causing problems. When I add a second disk to the Duo it crashes - I hear the ...
poisonrain
Yep - restart with factory defaults and 2nd disk (in 1st disk slot) worked fine. Visible in RAIDAR and fully accessible via http.
Off to Netgear support I go... hope it's better than last time
Thanks for the help!
PR
PR
