mothrat1980
Dec 02, 2018Aspirant
readyNAS Duo admin page
I have finally gotten my ReadyNAS running but I can't access the admin page. I can connect to the device through the web interface with no problem, but when it comes to the admin page, I get errors a...
- Dec 14, 2018
Finally got this working, I tried firefox 3.6, didn't like it. Soi went back even further to Netscape Navigator. I think the verison I got was 9 or something, but it was able to work. So another problem sorted!
Dec 03, 2018Guru - Experienced User
If you have internet security software running (particularly Bitdefender), then try disabling that.
Your firmware is at least 8 years old. 4.1.16 is the current firmware. It is possible that your problem would be resolved if you update it. Of course to do that you need to get into the admin interface. Perhaps try compatibility mode with Internet Explorer, and see if that gets you in.
If you still can't connect, you might try installing an old version of firefox. FireFox 3.6 was current back when 4.1.6 was released, so it should work. https://ftp.mozilla.org/pub/firefox/releases/3.6.10/ You will need to turn off automatic updates as soon as you install it.
mothrat1980
Dec 14, 2018Aspirant
